I had to put my x type 2002 through its 1st M.O.T with me owning it and I had to have some welding done to the sills + a bush on the rear .
The hand brake was a bit suspect as it comes up a long way but it passed .
I now have only one advisery on the M.O.T and that is the eye level stop light in the rear window dos'nt work .?????
How do you put a Bulb in there without taking the headlineing down .???? :(
O.T.H
Hi Frank,
There are comprehensive instructions in the Owner's manual for my S type for all bulbs except the one you mention!
This one on the s type is above the boot at the bottom of the rear screen, and I would be inclined to try unclipping the boot lining.
Other than that I would try googling it.
There will be a x type owner who will know and hopefully assist.
Petr
Yes with the X type its at the top of the rear screen , It didn't fail because of it but its nice if everything works .???
O.T.H
O.T.H
I think you have to buy the whole unit, rather than the Bulb.
Its the getting into it Peter and I don't fancy taking the head lining down perhaps never get it back right again then look a mess.???
Knowing my luck I bet its not a fuse or a wire problem
Frank
Not having a X type I cannot have a look, but I would not want to take out the headlining either,
