Hi all S Type owners.
I had the "service required" message on the Message centre and had some helpful suggestion of how to remove it  ----  used successfully on other models. Unfortunately they did not work on the s type.
I googled around and found a site in the USA [There are more S Types in the USA than the UK, I think] which worked.
You need nimble fingers and two right hands to start with.   And you have to be quick as 2 - 5 have to be done in 3 seconds.
1. Ignition key in the OFF position.
2.  Press and hold down the CLEAR/RESET Button and turn the ignition switch to ON
3.  Release the CLEAR/RESET button.
4.Pres and hold down the TRIP COMPUTER button on the left hand stalk multifunction switch.
5 Continue to hold and press down the TRIP COMPUTER button and press and press and hold
down the CLEAR/RESET button.
6  Keep both TRIP COMPUTER Button and the CLEAR/RESET Button and RESETTING SERVICE MODE will display in the message centre.
7  After 10 seconds SERVICE MODE RESET will display in the message centre.
8.  Release both buttons and switch off ignition.  Job done.
It took me 4 attempts before getting it right, but it worked..
Peter,
That is the one I meant to post instead of mine (XK), my mistake, sorry .
It does take a few attempts as it has to be done quickly . I think it works on the X type also .
The XK one I posted also works on the XF
ATB,
Trevor
No Problems, Trevor, I got practice in.
It will work  on the X type as the earliest smaller on the S type was the same as the 2.5 V on the x type and the whole dashboard is the same.
