Hi guys. Low keyfob battery warning appeared on my dash today . changed the battery in the fob.does the warning automatically go out or do you have to do it manually. Any ideas . cheers nigel.
Hi Nigel,
Does the new battery work OK? If it does and the warning does not go out I am guessing that you would have to remove the message manually.  I would use an OBD2 code scanner and delete the message.
I had a similar message  "Service Required" prior to having an OBD2 scanner, and was ablate remove by a tricky bit of jiggery pokerry.
hi peter, only tried battery from my second fob ,going to my local jag main dealer today, they can fit new ones , the second fob needs reprograming anyway, they can sort the warning symbol out, will keep posted. cheers nigel
All sorted.went to jags.they fitted a new fob battery.all warning symbols extinguished By itself Job done. Nigel.
