hi does anyone know if I can get a tow bar
for an 2006 xj tdvi witter and others don't seem
to do them ? thanks trevor
Hi Trevor,
I used to tow a caravan and although I was busy yesterday when I saw your post, I realised that I had seen several XJs with tow bars.
I had a problem getting one for my Rover Sterling and I eventually found a company that did one for it -  BRINK
I have checked their website  and BRINK appear to do a detachable tow bar for the Jaguar.  They also have fitting stations in localities across the country, and are rather good tow bars too.
You are quite right Trevor, none of the major manufactures appear to list an Jaguar XJ tow bar. However, from my google search I found various articles which included a write up on the car model being an excellent tow vehicle therefore, I suspect a tow bar is actually manufactured by A N Other. My own personal assumption is that Jaguar themselves supply it as an accessory. It may be well worth you giving a dealers store department a call to establish if this is correct.
I would just add a bit of totally useless information.
The Witter factory is positioned exactly on the spot where my office was at Shotton Steelworks.
