  • Replies 77
  • Created
  • Last Reply
Top Posters In This Topic
Cheers got it now. Double Dutch to me
Basically Phil, if you don't have any other D2B devices in the boot, plug in the D2B connector and power cable to the CDC - job done, except to find out whether your car needs to be told it has a CDC.
Other than that, it'll just be a case of bolting the rack into place and putting the trim back, but if you're unsure, just ask me... or head over this part of the world and I'll do it for you.
BTW, I have three spare cartridges - I bought them before I installed the ACM.
Hi. The serial number you gave me is for s type, would the one out of x type fit ending in code ab. Cheers phil
In the words of the old American Express advert:-   "That'll do nicely" :)
You can see a very clear picture of the connectors, showing the D2B connector and the small power connector to the left of the D2B. That will give you an idea of what to look for in your boot Phil.
Another one to watch:-
http://www.ebay.co.uk/itm/Jaguar-X-Type-Boot-Mounted-6-Disc-CD-Changer-1X43-18C830-AB-/121659469466?pt=LH_DefaultDomain_3&hash=item1c53782e9a
You'll need an appropriate D2B cable Andy, either buy the correct item with three ends or buy a two ended cable and modify your existing one.
Crikey Phil. One thing at a time mate :rolleyes:
Only joking. You'll need the GPS aerial.
You intend to go completely touchscreen?
Yes Phil, each module must be in the network topography for the system to work so you'd either need to get a cable with the correct number of connectors or modify one that you might already have.
Retro-fiiting touchscreen would be an ... interesting project :lol:
Eminently do-able though, I would think. I'd need to do a bit of research to be sure.
Phil, I just checked up on what I thought might be the biggest problem with retro-fitting sat nav and I got the best answer back :lol:
Do you have the digital climate controls or the manual knobs?
If digital, the touchscreen operating system controls everything perfectly and I'd suggest you go for bluetooth and Jaguar Voice as well :lol:
If analogue climate control, to be fair, I'd forget it... at least for the time being :(
