Hi anyone know if you can change the front lower ball joints or do u have to buy the compleat lower link arm on a 05 model (£300+ from jaguar)
Hi Thomas
I looked it up and==
It tells me in the S type manual that -"The lower ball joint is serviceable and is a press fit" .???
It says that the lower control arm -Is mounted with one Hydro-bush [the front one] and a rubber bush
both are seviceable.???
But the upper control arm you have to purchase the complete arm.????
I hope this helps.
Frank
You will need a wedge type ball joint splitter to remove the joint Thomas, quite reasonable from Euro Car Parts
Thanks guys now trying to locate the right ones, jaguar adamant that with my vin number I need to purchach the compleat link arm at £350 each, a young lad on eBay is checking if the ones he sells will fit and negotiating with garage as to fitting, offerd use compleat arms on flebay bu hesitant as to fitting used joints, will keep you posted as 2 how it progresses.
