had eml on last week diagnostic was showing maf sensor, so I got home from garage and took sensor out and clean it. Put it back and all was fine light was out. Eml has just come back on again tonight so cleaned again but light still on. I've not had the code reader done again yet to see if it's same IE maf. Is there anything else that can go wrong on the sensor, I've noticed there's a rubber seal on the sensor could that be at fault? Beginning to dislike the jag as it just seems fault after fault
Have you thought of changing it??
Jacksons car spares in ewloe have one in to break and last time I was there it's engine was complete.
Light gone of tonight on own accord, seemed a little under power when light was on now it's off seems a bit more power?
