Hi All
Just joined the forum as I've bought the infamous S Type with the blowing fuse issue.
The car has arrived now so I intend to tackle the fuse problem and the engine management light which appears to have started at the same time. The car has had a bump to the near side rear quarter which I stripped out earlier today and intend to repair and the damaged area. One thing I did notice was that phone module is cracked around where the multi plug pushes in and the circuit was slightly open. Now, I'm not saying this will cause the fuse issue but hopefully one of you guys will advise ?
Are there any further modules or connections in the rear quarter area which could be effecting the electrics, bearing in mind that prior to today the rear wing was pushed in far enough to push on the loom
Any pointers would be much appreciated
Darren
Hi Darren, and welcome to the club.
You have already seen the posts, and you can guess that there are are a lot of helpful people in the club
Good luck with the issues.
