2002 S Type security dash light flashing rapidly. No start until I turn on and off ignition several times. The light goes solid and off and then it will start.
But now it suddenly stalls while driving and I have to go through the motions while stalled in traffic.
What could it be?
Mike
Hi Mike,
The first thing I would do is check your battery. An S type needs a battery about 95 AH and they usually last about 5 years.
Hi all.
 I agree with Peter, before you panic over these little nigely probs Keep that battery  absolutely topped up. and wiggle your fuses occasionally. you might be supprised what turns up. especialy the battery, a fraction of a volt can do all sorts of silly things to your S Type.
Stan
