Hi, and thank you for taking the time to look at my post. I recently bought an s type and have a fault with the central locking. When I turn the car off and jump out I press then fob to lock it, it locks then immediately unlocks. But if I walk round to the passenger door then open and shut it, the central locking works properly.
Has anybody had any experience with this and have a solution.
Many thanks
Hi Gary
I have a X Type and I had a problem similar to yours but mine was the drivers door .??
I think the S Type is the same and has a small locking  lever next to the inside door handle
well it was sticking ---So to cure it I was told to------
key in and ignition and on -drop the window --[the passengers side in your case]--and then
work the small lever a few times so it frees off ----Switch the ignition off and try the locks
if that cures it a small amount of WD-40 in the lock could be the answer ..?????
I hope this helps
Frank
just gone out to have look and it is the internal lever that is a little stiff will jam a bit of wd in there and work it. Thanks for the help
I don't know about jamming a peace of wood in because you could break it ???
Like I said stand out side the closed door with the window down reach through
and move the small lever in and out with a little WD-40 ???
Frank
