Good afternoon fellow Jag fanatics,
                                                        Does anyone know what has caused this problem? I changed the 3 spark plugs on the drivers side bank (underneath the intake manifold) a few weeks ago & everything was fine. Yesterday, I changed the 3 plugs on the passenger side. (the easy ones) She ran just fine for around 20 miles, now I'm getting up to 3,000 rpm & she's coughing & spluttering. I can't see why & need your thoughts on this, PLEASE...
post-7880-0-85295100-1444576862_thumb.jp
Hi Andy --You say its on the easy bank so if it was you I would put the old plugs back in and
if it runs OK again it would mean that one of your new plugs is breaking down under load
[ It does happen at times ??? ]--you can then change them one at a time to find the bad one
and get it exchanged.
All the best.
Frank
  • Like 2
All the best.
Frank
This happened to me about 45 years ago on a A40.  Just because plugs are new doesn't mean they are perfect.  I still have a feeler gauge somewhere!
  • Like 2
Did you change the coil packs as well and did you use oem quality? Gaps on genuine plugs came preset on the ones I just changed on my 3.0 Sport, perhaps you had a dodgy fit or connection somewhere?
