Heater Stuck On Hot!!! HELP, i'm getting a tan!!??
2007 S-Type 2.7D, i only get hot air coming from the heater which is very annoying on long journey's and i'm sure will be impossible in the summer - does anyone have any words of wisdom/solutions, ideally inexpensive ones please???
Sal
Sorry Sal never come across that problem. I have had it on others cars the opposite way round which was usually the result of the thermostat being stuck open however if it were stuck closed you would have engine overheating problems. My guess it's got something to do with the air con. Let's someone comes on who may have experienced the issue
Don't know much about the diesel's
but I would say either the heater valve has failed or your webasto is stuck on
the heater valve controls the hot water into the heater radiator and is a common failure
the webasto is the aux heater for start up time as diesel take ages to warm up the water
if you type in s-type heater valve on eBay you will see the valve i mean, there specific to model and year and new ones are not the cheapest
I think you can pull a fuse for the webasto aux heater to eliminate that
joe
Hi Sal,
I've got similar problem on my stype diesel  , it blows hot on drivers side only. I was told the heater valve could be the problem so I bought a second Hand one from eurojag and its being fitted this week. Hopefully that will sort the problem out.
Hope this helps ,
Gary.
Hi Gary2008, can you let m eknow once fitted if that has fixed your problem?
Sal
  • 4 years later...
Hi guys.. i have the same problem, it blow hot air, changed the valve and still.. if you fixed your problem please clue me how, thx
