Hi I have a XJ 2008. The car jitters ONLY when the weather temperatures outside is below 6C  AND you switch the climate control on. This jittering continues until the car engine reaches constant running temperature OR you switch the climate control OFF.
I have taken the car to a main dealer and they have replaced ALL the injectors and the engine mounts, this has improved the situation but not solved if. Now the Dealer is at a loss too.
I could do with some advise on how to solve this situation if some one else has had the same problem or knows what the problem may be.
Thank you
Munir B
