This comes on intermittently. When it first came on it was right as my front right was a bit low. However it still comes on now and there is nothing wrong with the tyre pressure. any ideas?
15 hours ago, Henry said:
Probably the sensor they do tend to play up.  Have it replaced.
Cheers, I'll monitor it for now until I change the tyre next week.
  • 4 weeks later...
Hi guys,
I have had my XF for over 4 years and the tyre pressure warning indication came on pretty much when I got the car. On another forum I was advised to let all of the tyres down to around 2 bar so that all of the tyres indicated low pressure. When you have done this, start the engine and inflate the tyres to their normal pressure. This works but after a few weeks the false indication starts to reappear and you have to go over the process again. Does anyone know of a permanent fix?
Rob
On ‎28‎/‎03‎/‎2016 at 4:40 PM, RobbyD said:
Hi guys,
Rob
That really does sound like you have a faulty indicator.
Mine has not come on for a month now, fingers crossed its sorted itself out.
Sorry to jump in on someone else's thread but...
Last week I managed to collect a screw in my rear tyre in the car park at work. I think it was probably flat before I left the car park but I didnt notice until the horrible noise started.  The question is, I didn't receive any tyre pressure warnings at all.  So, if the tyre is flat when you power up the car, does the system not recognise it as a loss in pressure?  Seems a bit odd but at the moment the system seems pretty worthless.
Also, how is the system reset after the tyre pressures are all set at the correct levels after a period where the pressure has slowly dropped off by a few psi?
Any help gladly received :)
