Well, I thought it was going to be easy. It was easy... it just didn't work.
Can anybody clue me in to how to wire up a tow-bar fro an S-Type please (12N socket only).
Denis and I took most of today, well into darkness, getting his tow-bar fitted. I wired it up using a 7 way bypass relay module for negative switching and it just failed to operate any trailer lights, although the wiring was double checked, the by-pass relays were heard to click when the appropriate light was switched on and the 12N socket wiring was also correct.
The instructions failed to mention what to do with the white (ground) wire from the 12N socket but I tried it with the wire both connected to ground and also disconnected (floating).
I used a TEB7AJ bypass module and a TEB1 to provide 12 volts to the TEB7AJ I can confirm that 12 volts was getting to the TEB7AJ.
No wonder tow-bar fitting centres refuse to fit to the S-Type.
Has anybody had a tow-bar fitted please or better still fitted one themselves and can point me in the right direction?
Thank you.
Thanks Andy. I've already done that. The TEB7AJ is designed to perform the required function.
@Simon. No idea. Denis got it.
Hi Paul --Can I just suggest that you run a separate earth wire from the tow-bar to the
caravan and if you have one make sure its OK???? --Metal to Metal do it temporary to
see if it works --Just a thought.
Frank
Probem solved.
It was all down to very poor instructions.
Moved the module ground connection direct to the battery and it all works perfectly.
There were a few other ambiguities and anomalies in the instructions as well but we worked those out yesterday.
Result? Tow bar wiring on the S-Type is in fact dead easy :yahoo:
  • 3 years later...
Hi, sorry I know this post is old but HELL I'm stuck!! if Raistlin is happy to supply a little bit of a guide as to wire an s-type tow bar I would be eternally grateful. Many thanks Mark
