Hi Paul
Looking at the units on sale I see one seller says his is being sold with a connection code ? No one else mentions one.  Can you confirm whether or not a connection code is required with the module 7W93-10D893-AB plse ?
Ok thanks for your input. I have avoided that one.
Many thanks for your help.
I shall just wait for the parts and see what I can achieve with them......🙂
  • 5 weeks later...
I have just bought a 2003 S-Type R and have been reading about the phone / bluetooth option. Called the Jag Dealership and asked about the C2N 3689 module to put into my car; they said they couldn't find the part number. Does anyone know if my car "has" a place for it and will it work? The Vin is: SAJEA03V031M72242. I would like to "fix up" the inside electronics with whatever is available. It does have the 6-CD player in the trunk, but it seems a bit off - any suggestions?
Appreciate any advice.
to EJG, Hi,
If yours is an import from Japan the following will be relevant and of some help in understanding , if not you can ignore it. 🙂
My S-type is imported from Japan and I can tell you you that the wiring in the boot is not standard, it has wiring for CD changer and Sat Nav(which are functioning)  but not normal Voice unit or  Phone/blue tooth wiring in the harness. I am trying to devise my own bit of wiring to enable such devices to be fitted.
  On 11/25/2021 at 8:15 PM, DaveHx said:
to EJG, Hi,
Appreciate the advice. I'll look to make sure "where" it comes from.
Ej
Ceiling Microphone Volume too low......
Hi  following on from my previous notes I have now fitted Voice and 7W93 bluetooth units to my S-type . I had to make a small wiring harness with plugs and replace the Japanese sat nav with a european one. All did appear to work ok. Phone book loaded from Android phone into car . Calls can be made and received. Voice commands working. Problem is I have to shout at the Voice to get  a response and while using the phone my voice is very low volume at the other end and callers struggle to hear me. I had fitted a microphone to the ceiling next to the roof unit and plugged it in the usual place. Can anyone suggest where there may be a means of boosting microphone volume output or maybe I should just find and try another microphone ?
Has anyone else had this problem and found a solution ?
Hi, Problem solved the microphone is now working fine. Must have been a poor connection, while I was trying different things it suddenly came on strong. Just have see how long it lasts..........
How do you make a D2B (fibre optic loop) connection? Do I still need one (D2B fibre optic loop connection) if I fit Jag voice?
Many thanks.
  On 3/12/2022 at 2:06 PM, Nealey13 said:
Many thanks.
You can buy an appropriate lead from fleabay or make one up if you've a stock of cables / connectors.
You need a D2B connection for Voice.
  • 2 years later...
I have just received  module 7W93-10D893-AB to install BT /Phone in my 2007 S type unfortunately neither of the spare connectors  behind the CD player fit , the car has Jaguar voice also, the larger connector is white and the smaller one black there is also a single optic spare
  • 5 months later...
