I have had an intermittent problem with ALL windows not opening/closing on my S type. Now not worked for two days. I want to check the fuse no 22 .  How do I access fuse box in passenger side?
Hi Kenneth,
The fusebox in the passenger compartment is on the driver's side to the right.
Torch needed.
Hi, thanks for that. I have checked fuse and is/was ok. I still have problem though. Any ideas?
Cant hear anything. Its as if there is no power. Could it be the regulator I wonder?
