After having owned my S-Type for a close to 5 months now, I have only just realised that the headlamp washers don't function.
I have the washer "flaps" on the from, but they never seem to operate.
Getting to the underside/back of them seems difficult to say the least.
Is there a "how to" guide anywhere relating to headlamp washers please ??
Thanks.
7 minutes ago, Old Peter said:
You have to have your lights switched on.
I knew that :yes:
If you want to do anything on the headlight washers you'll need to remove the front bumper.
It is just possible to get the the pump, which is attached to the screen washer bottle, by removing the wheel arch liner on the off-side. I'd apply 12 volts direct from the car's battery initially to see if the pump was at fault. The headlight washer pump is the one with the thick pipes to it.
Before you do that though, it would be owrth checking out the fuse / relay by substituion.
Good idea - I'll check it out at the weekend.
Thanks.
