Changed all the interior bulbs today. Why didn't i do this before the difference is startling to say the least all for £20.
Hi Ian,
Did my boot lighting a little while ago and added an extra LED module to improve things, link below
improved things tremendously.
Andrew
This is something I've heard a lot about Ian but never seen it for comparison in an S-Type.
Would it be possible for you to upload some pictures please? I'm very keen to see the difference :yes:
Just got in so took a quick snap of the illumination within the car, have no pictures of what light was before change, believe you me Paul if you do this you wont be disappointed, the only ones I have not replaced are the reading lights in the rear seats, kept them as original did not want to be dazzled if they are used when I am driving, I am sure you see this as a safety issue.
HI Ian,
That lighting looks great.   It makes a great difference in the footwells, particularly. Where did you get the bulbs from?
Now that looks well worth the effort Ian. Thank you for the photo.
Would you have any links to where you got them please?
7 hours ago, ian6 said:
All led bulbs were purchased from my local motor factors, 8 bulbs came in just under £20
Thanks Ian :yes:
Hi Ian,
I have  been contemplating this for a while...in Amber or orange. Guessing yours is in white?
its a cool upgrade and I've seen it in the orange and , whilst it's not great for reading and the like, it's a fantastic warm glow that matches the dash oranges. As my interior is two tone grey it should look cool.
well done mate looks fab. Once I've done a list of the type and quantity of bulbs I'm off hunting for orange led bulbs.
will post a snap at night to show an alternative colour to yours. Yet again a great idea for others to see the possibilities with these cats.
steve
Looking forward to seeing what the orange looks like, good hunting for the orange bulbs, there bound to be available on the internet. Regards
does anyone know where I can source a list of interior Bulb types and quantities?
Started digging through the interior and have, as usual, got frustrated trying to get at the bulbs....even managed to stab myself with a screwdriver!
looked in the owners handbook and can't seem to find anything.
appreciate any assistance
Steve,
To get the overhead light console down is as you did it when we installed the microphone. Then the bulbs are push fit into the white plastic Bulb holder assembly.
How did you possibly know I was having issues with those bulbs? Have you fitted a camera in my car?......lol.
am on the case paul.....trying not to get frustrated with the fiddly bits and checking the bulbs ready to source.
Still hoping for a list of bulbs to make my life easier.
Thanks for the assist.
It is possible to pull out the white Bulb carrier assembly after you remove the overhead console Steve. This will make Bulb extraction easier but if you do so you must refit the Bulb carrier with the two retaining clips. If you do not use the retaining clips and just push hthe bulb holder in to place you may never get the overhead console down again without destroying the head-lining.
Been there, nearly done that. Nearly got the T-Shirt.:yes:
bulbs needed:
Overhead console -
- Requires two 194 bulbs
- Requires one Festoon
Rear overhead -
Flip down visor (1) -
Don't know yet
Footwells -
- One 194 bulb
Boot Light -
- One Festoon
Map light -  WLED-xHP15-TAC
**Bulb info above not mine. Acknowledgement to the original author.**
Thanks paul,
yes im being gentle ....at least I admit I'm a little heavy handed at times. Thanks for the list....I can start chasing bulbs without breaking or bleeding!
will hopefully source new bulbs and fit them shortly......then if it looks right post a few pics.
Fingers crossed my colour choice is right!
Be good and take care
Try as I will I can not get the front map light covers of and don't want to break them please what am I doing wrong
Unfortunatley, I'd suggest that you won't be able to get the bulbs out without dropping the overhead console. I certainly can't but I have fingers like pig's trotters.
11 minutes ago, Gordy said:
Ok thanks for that Paul I really should read up on things before I start
Better still, ask on here :yahoo:
It may be possible anyway, Gordon
So changing the existing bulbs to LED's didn't cause any problems with the Jag's other electrical systems?  I was considering changing the parkers (sidelights) to LED's but read somewhere that changes to power loading can cause issues.  Not true?
No I have had Led sidelights in since I got mine no problems at all
