Hi guys,
I am new to this forum so please forgive me if this is in the wrong place or has been a topic before. My car alarm sounds shortly after I lock the vehicle. I was wondering if anybody else has had this issue in the past? If so was it an easy fix? Any replies would be helpful.
Hi Jon,
I'm new too!
I've had this issue as well. It'll happen if any of the doors aren't fully shut or the boot is open. If everything is fully closed then it's simply your key fob losing communication with the alarm receiver in your car. Taking the fob out of your pocket will normally re-establish the link and the alarm will set.
Hope it works for you,
Cheers,
Dan.
Hi Dan,
Appreciate the reply. I did go round and check all the doors and boot first time it happened as I'm a bit OCD like that :). Could it possibly be the key fob battery needs changing?
Jon
dont think the keyfob can do that
usually when there is feedback from a keyfob the it would indicate on your dash with a message saying keyfob battery is low
usually the main things are a dodgy door that does not lock, interior ultrasonic sensors, a window is open, boot is open or bonnet is open
if you look in your handbook, it should tell you what to look for, ie on my car s-type, if you leave something open the indicators flash a certain number of times to let you know,
also when the alarm sound and you disarm it the indicators flash again certain amount of times to let you know your alarm was triggered
joe
Hi Joe,
Thanks for the reply. Some light reading for me this evening then. Appreciate the help.
Jon
Hi Joe
Just checked the car now and went through settings as instructed like you said. Came up with "alarm triggered by volumetric sensor"
Thanks Jon
thats the interior sensors, not sure where it is on the xf
usually by the interior light or top of pillars each side of windscreen
these usually only go off when you leave a window open or sunroof
try dusting them off, just in case it dust
joe
if you arm the alarm by only pressing the lock button once, the volumetric sensors are disabled, for when you leave a pet in you car say
Hi Joe,
Thanks for replying. Is there anyway of clearing the message from the screen or will it fix itself after the problem has been sorted?
Jon
Hi guys,
Just an update. As I set out for my journey this morning a warning message came up saying bonnet was open. I haven't had this message before so I am guessing this was making the alarm sound but time will tell I guess. I have just double locked the car and no alarm. I am hoping this is now fixed. Will keep you updated.
Thanks again guys.
Jon
