when you changed the filter did you fill the filter and both lines with diesel
if you get a air lock it wont start
when you take it off, first fill one line, then put the filter on, fill the filter with diesel, fill the other line and clip it on
if it starts and cuts out repeat the above, don't keep cranking the car, because if the injector pump runs too long without diesel, it can damage it
joe
  On 8/23/2016 at 11:03 PM, JOE-DOT-COM said:
joe
Expand
i have now lol shes running again but boost leak
