I only have one key for my x- type and could really do with a spare . Does anyone know of the best place to get one and programmed apart from the main dealers ? Cheers .
Wow no Gary , that is a fair whack for a replacement key . I knew it would be a fair bit but £300 + is a eye opener . I think i might just stick with the one key and be very careful with it . Thanks for the heads up .
hi andy, i hope to get a spare key myself !    i found a jaguar breakers up in derby (auto reserve) who if i drive up there will find the right key and will also place the key in my ignition, program it and make sure that everything works. £30       so search on the net for the same in your area to see if anyone can do the same?   good luck, dave
Try some local locksmiths near you
I have one near me, longton locks, they will cut the key and clone the transponder and program the remote
the keys have been out years standard ford ones
if you buy a second hand remote it works out even cheaper
joe
19 hours ago, JOE-DOT-COM said:
joe
That might be worth looking at Joe . I will have a search on the net . Cheers.
  • 4 weeks later...
It works on ,my computer. Try typing thecarkeyman into google if you cannot get the link to work.
or try calling  01522 514141
Hi just read your problem.
I needed a spare key for my newly acquired X type.
I know you are a good distance away but BESTWICKS of Derby "see website" are ordering me a key. Jaguar is one of the only ones they don't stock.
They guarantee a new key, cut and coded for £75.00. Of course they need you. id. and the car to do the job.
Hope this might help other folk.
There is a Nottingham company, 3D Autokeys. who do the same but at your home for £130. they cover a 40 mile radius from Notts.
  • 3 years later...
have you tried eBay I wanted a replacement remote and I got one on eBay with a blank key, the key part is th same blank as a Ford you may be able to get it cut at a ford dealership which is a lot cheaper than jaguar as for programing you can do that quite easily with your original key.
  • 2 months later...
Anyone know where in the Bournemouth Area ,Apart from Jaguar Main Dealer would do a replacement key and program it, Always handy to have a Spare
Bazzer
I got a replacement used key off of FleaBay for £ 12.00 ,two new 3 Volt CR2032 Lithium Batteries  for £ 1.95 and checked on Google to reprogram the key its a 5 min job Easy
Bazzer RN
