2011 Jaguar XF 3.0 L D Premium Luxury (112,000 miles) - Had a slight squeak that sounded like O/S front wheel.  Upon investigation we noted a bit of excess play on the O/S front wheel bearing so changed it anyway bearing in mind the mileage.  The job went well.  Have only travelled a couple of hundred miles and road noise is better so probably was correct diagnosis.  However, today I heard what I think is the same squeak, only louder.  If it is the same one, which is not constant, although usually squeaks for the first few bends.  No ABS warning or any other for that matter!  Once driven a few hundred yards it nearly always clears itself but I need to diagnose properly.  Anything obvious come to mind?  Any advice appreciated thanks?
