I'm in the process of replacing the windscreen wiper motor and linkage assy due to lots of wear in the right side spindle (RH/D Car). However upon removal of the plastic Lower Windscreen Finisher (or scuttle) I could see that what appears to be "padding" on the underside that has broken up and retained a lot of water which in turn rusts and corrodes everything below it. This water/moisture also messes with electrics and a sensor (on the STR) which reside at the rear of the engine bay.
My question is can the damaged "padding" just be discarded before re-fitting the finisher or does it have some really important function that I am missing.
Would appreciate any advice from those that might have encountered the same issue.
I binned mine for the same reasons that you are considering Brian. Never caused a problem thereafter.
    • Jaguar Icons
      • 11 replies
