I have just bought a 2003 S-type. It is my first Jaguar aince 1968 when I ran a 3.8 s-type.
I am delighted with it so far. It has SatNav and an on-board Motorola telephone.
Is there anyway that I can unplug the phone and replace it with some sort of adapter which would enable my mobile to take its place ?
Why not just get an adapter and charge it from the cigar lighter?. Have just joined too and have 2 of those S Types a 3.0 v6 and a 4.0 v8. Plus 2 other older Jags.
Hello Andrew, welcome to the Jaguar Owners Club :)
Yuo can easily upgrade your car to Jaguar's bluetooth system which will link with your phone and link it into the car's infotainment system. Do you have a touchscreen?
I have a touchsreen yes. What I want to happen is for my mobile to have the same facilities as the in-car motorola handset. EG, ring in the car through the speakers, display who is calling, switch off the music and be able to speak hands-free. Then when the caller hangs up for the screen to go back to Nav, Audio or climate and the music to continue where it was interrupted. In my Volvo, I had a Yatour system which plugged into the multichanger socket, but it had no touchscreen.
Thanks for your help so far.
Where are obtainable from ? Also on my old Volvo, the head unit was easy to remove. On the Jaguar the radio looks impossible to access.
But I would like to have bluetooth. I listen to talking books which are stored on my Android mobile.
Thanks for your assistance.
Head unit (Touchscreen) is easy to remove Andrew. However, this retro-fit doesn't require your head unit to be removed.
Easiest way for you to do the upgrade is to buy one of the later combined phone / bluetooth modules part number:- 7W93-10D893-AB.
Which are quite common on eBay.
You will not need anything else. The D2B fibre optic and wiring will already be in place.
If you decide to go ahead, I can talk you through the process if you want.
I am minded to keep the car phone. I think it is quite quaint. The problem is that the slider which holds the telephone SIM card is missing. Does anyone have one out there in the Jaguar world ?
Andrew
