Hi everyone I've been having problems with the rear passenger window. The window goes up and down as it should when I use the drivers switch but when I use the switch on the door it just goes down even when I use the switch to make it go up.
I've changed the switch as I thought it was that but it still does it.
AnyBody got any ideas?
I'd check the wires leading through the flexible conduit between the car and the door for breaks. The wiring through these isn't very good IMO as my 2006 example has nearside passenger mirror problems and my offside front door speaker does not work due, I suspect to broken wires. I'll investigate more fully when it gets a bit warmer.
