Hi all just bought a 2003 S type R. Needs a bit of work which I'm doing myself  but shouldn't take that long. So I will be asking for help no doubt...
My name is George and once again hello.
Hi Joe I will get round to putting photos up. But on first look needs the zf gearbox filter change as leaking low Oil. In limp mode. And a heap of welding on both floor pans. new drivers side wing and the other arches rubbed down and treated then paint. Just as well I'm a mechanic lol....
If the gearbox is low on Oil, you will get faults
you can get kits off eBay, that have the pan/filter, pins, Oil and mecha sleeve in the kit reasonably easy to do, go on youtube, jagtv theres a video showing how to do it,
change the mechatronic sleeve, on the gearbox, as there known to leak on earlier cars, later sleeves have been altered to fix this
personally I'd get second hand wings as there cheap and might be lucky and drop on the same color
check your brake pipes as well there a weak spot on these
if you need any manuals pm me and i will sort you out
