My battery seems to be running on low for a while now, sometimes the car won't start. Did 500 miles the other day and that didn't charge it either. Do I need a new one or is it something else?
Ta
If you go a battery place, they will put a test on it
they should check the voltage with the engine off above 12volts, Ideally 12.5volts and on, engine running about 14.5volts, if its below 13volts could be alternator
they usually put a load test on it which will tell them if the battery good or not
if your cars a diesel and the battery is over 5 years old its due for a new battery any way
I'd get it checked, make sure its charging, if it is put a new battery on it
just check the obvious, make sure there's no interior lights stuck on, or glove box or boot, that will drain the battery
Cheers guys. I'll check the conections tomorrow, if no improvement will drop it into the garage. Think battery about 5 years oldnow anyway.
Ta
That's the first sign of a failing battery.  Mine was 4 years and 11 months old when I changed it.
Everything perfect now even when it is freezing.
