Hi all I'm currently running a 2003 2.0D X-Type with a 5 speed gearbox. I have a 2007 parts car which has the 6 speed box. Is it possible to swap out the 5sp for the 6sp?
I used to  have a mondeo tdci which had the 130 engine and a 6sp box which got me thinking as it's the same engine in theory it should bolt straight on, I'm just wondering if anyone has done it
Thanks for any help I'm advance.
Dave
Its most likely bolt straight on, though the two gearboxes are completely different, problem is getting the new gearbox coded to the existing engine
you would have to ask a jaguar indy and once you swapped it, its not going to drive till its programed to your car, so would have to be trailered to the indy garage for programing
years ago you just swapped and away you went, now everthing is on a can bus type comms and every module talks to each other and are coded to each other
Thanks mate I thought it might have to be coded. Oh bring back the old cars that us amatures could work on life was so simpler back then
I still have my tool kit for the old cars  ---  an adjustable spanner and a lump hammer!
