Posted (edited)
Hello all.
Went to start my  x type and noticed had n/s dip out.
Looked around car and saw all lights out?
Turned to light on and all but n/s dip came on.
Main beam will also not stay on but does flash.
Any help out there please.
PS, I have checked the fuses but can't find info on relays that are in circuit. I need a circuit diagram for a 2005 please.
Edited by Mallorr
Spellinh
Every thing goes through the front control module, if there a low resistance on the Bulb or a fault sensed it may not light up
Try swapping the Bulb, also check the headlight connector, terminals sometime melt and short, causing a fault
here a Electrical manual X-Type Electrical Guide 2004.pdf
and workshop manual Jaguar Workshop Manual X-Type 2001-2009.pdf
manuals are off tinternet
Hi Joe,
not looked at it yet.
now I have wiring I will follow it.
thank you kindly for the info and will keep you informed and post findings if any.
malcolm
