Hello Everyone
i hope you are all enjoying Good Friday
Mine has started off rather badly my multi disc player has all of a sudden displayed an error message I tried to eject the cartridge with no success it was trying to eject but wouldnt
I kept trying the eject button whilst gently touching the cartridge and it popped out
I removed the discs and then put them back in the cartridge back in I watched as it loaded each disc and unloaded them one at a time then when it finished I looked at the screen and the message came back on
The cartridge would not eject but after a little coaxing I have it out
can anyone help me it has worked fine until today
Your advice would be very much appreciated
There usually quite robust and trouble free
but they do fail with age, there's a couple of ribbon cables inside, one could of fail giving you this problem
did it fail while it was playing or after you changes some of the discs
Hi Joe
Thank you for replying it actually started when I went from navigation screen to the CDC screen to select a disc
i have seen a repair service on eBay while looking at the second hand replacements so I think I will give them a go £45.00
if you know where I could get the ribbons I would try that myself first
Thank you once again
Andy
At least with the repair service you will get a guarantee
the inside mechanism floats on a damping system
just out of curiosity, have you tried a CD cleaning disc in it first, you can also get a bit of dust inside it and it can stick to the laser that reads the disc
there usually available for less than a £5, its a cd disc with fine brushes on the disc and it will clean it, maybe worth a try for a fiver
