need help/advice please, picked up my 2007 x type se today, ( very happy) when i touch the phone button it states no phone fitted, tried the 1313 code no help,looked in menu no help there either so i have been looking at handsfree setups.... now very confused....recommendations for handsfree kits would be appreciated. thanks
Hi there unless you are looking at going down the factory fitted phone setup the best after market set up is a parrot hands free system, as you will gain the ability to stream music from phone etc
dont want the factory fitted ones, been looking at the parrot systems they seem ideal thanks
The one you want then the parrot mki9200
have fitted these before and they are very good
you can also get the jaguar parrot loom that makes it plug and play
hi Tony
I have the Parrot system in my car, kindly left by a previous owner, I can confirm it works really well, if I had one complaint, the remote gadget (which you can fix in a place that is conveinient for you) is a pain in the proverbial! it works when it wants, even though I replaced it last year. and as Dave said above, getting music off your phone is reltavley straight forward
regards
I have a motorola TK30 and it works lovely, the display sits nice just under the centre vents and the mute/answer button on the steering wheel answers calls.
can stream music to it too.
had a look at this Bovril, do you need any special leads/ loom cables to use the steering wheel controls
