Used Parking Aid Module 4X43-15K866-Bc
HW02 SW02 CODE01
The item was tested and working correctly. Please before install check the compatibility of you hardware, software and the code(It can work on older ones, not sure about the newer versions). Also before install delete all the fault codes, if they are not deleted and you have pending ones, the parking aid module may not start working.
Postage: Around 1-3 working days.
