Stephen Hi, I have just purchased an XF and was looking through the documentation for my code. If it's the same as my old X-Type then this is the code you will need if you disconnect the battery from the car. It will prompt for the code when you reconnect the supply. If it's a model with 2 batteries, I assume it would be the ancillary battery not the engine start one. But I would be interested to hear if others agree. I am very new to XF ownership and the forum so although this was what the code was needed fo on the X-Type I may be completely wrong!
Best regards, Andy.
