Hi guys here is a easy way of getting the crankshaft pulley bolt off with out using locking tools.Ok right I found a way of getting the crankshaft pulley bolt undunn.  to Remove put socket on to bolt.attach a long breaker bar.put bar down to the floor.then get some one to just put a bit of pressure to stop socket springing off.then put key in ignition and flick the key just very quick this then forced the crank to turn clock wise and bolt anti clock wise and will undo the bolt.i had to flick key a few times as the bolt was well tight .just remember only a quick flick of key just so it turns crank over.oh also make sure the breaker bar fits between the anti rollbar and the lower half of the engine to stop it moving out wards. .this is the perfect way.
