Hi All,  Newbie here.   Got into my 2008 X Type estate last week and put an address into the Sat nav.
It was calculated and i told it to set as destination and start.   as i moved off from Home, the Nav seemed to move off the roads i was on!
It now believes i am actually 40 ish mile southwest of where i am.  I have gone into the menu and reset my location, but as i move off it goes wrong again.
Anyone got any ideas.    I've also removed and reinserted the disc.
Tony
Hi Tony,
I have given this some thought and the only solution I could think of you have already done, ie Disc Removal and resetting location.
Maybe the disc needs cleaning?
If I recall correctly, Denis had this problem with Stacey's S-Type. Unfortunately, I can't remember how it was rectified. I'll ask him.
Spoken to Denis. Stacey's sat nav problem was solved by going into map options and dragging the cursor across the map in stages until it was sitting in precisely the right position then hitting the "OK" button.
Is that what you've tried already?
Hi this is easily fixed go into vehicle menu then calibration this allows you to move the cursor to exactly your position then just save it really is simple and is explained in the X Type handbook if you don't have a copy let me know and i will photocopy the pages for you,  I also upgraded my satnav disc to 2012 version works perfectly and has newer maps than that found on the 2008 disc again if you need help PM me davecox3@icloud.com
Hi Dave.   I have done that, but my not have saved it so i'll do it again and make sure i do save.  I'll get back to you either way.  BTW where did you get the 2012 disc from?
Tony
Tony
Tony I have  new copy of the 20102 disc you can have it for £15 if thats any good
yeah i'll take that off you.  just let me know total cost and i'll send you my details.   how will you want paying  'Paypal' as a 'payment to friend' or however you want just let me know.
Gonna try and fix the issue with the satnav now so i'll let you know how it goes.
tony you can pay me via paypal my email address is davecox3@icloud.com it will be 16.50 inc postage and packaging will put full instructions in but basically you just put the disc in switch on and wait for the disc to load takes about three or four minutes while it updates everything then go as normal
