How do I find out the age of my battery on my 2008 x type diesel ? I know its not priginal as it says Mercedes on it. Just had to jump start the car.
Rod
Hi Rodney,
There should be a code heat embedded in the plastic case of the battery near to or on the top face. The first two/three characters typically refer to the date you're looking for. The alpha character should be in the range A to L or M where A=January and L or M equals December (some manufacturers omit the 'I' as its thought to confuse. The single or double numeric digit indicates the year.
You should note though that the date can also mean various things other than manufacture date e.g. Start of Warranty, Date originally charged, and others.
Hope this helps,
Replaced battery with 80Ah. The battery taken off was the original dated 08 but 70Ah, so its done quite well really. Fixed label on top so I know when replaced.
Rod
