As Iv just bought the car I’m finding little problems when driving it today the automatic box seems rough when changing gear mainly the low ones and if I put my foot down it’s !Removed! a manual clutch slipping anyone had this thing before and knows roughly what it is thanks guys
Hi Andy,
Any warning lights at all?
Have you got access to a OBD2 code scanner?
What miles has the car done and has the gearbox Oil and filter been changed at all?
Hi Steve
theres no warning lights.
yes Iv got a obd2 code reader( dunno where the slot on the car is located)
iv Just bought the car so I havnt got a clue when or if the fluid and filter has been changed.
the car has done just over 163,000 miles but was told the engine was changed to a engine with 80 somit thousand miles no sure when tho as Iv got no paper work with the car but looks like coolant and engine Oil has been changed recently
Hi Andy,
Raistlin is right so best first option is to get the Oil and filter changed as soon as you can on the assumption its never been done.
The OBD2 connector is to the left and underneath the steering wheel in the footwell. It can be a bit a faff to connect, I always have to kneel outside the car to get eyes on while I fit the scanner, but once done you should be able to read any DTCs recorded in the various systems.
By the way Raistlin recently posted a thread containing links to workshop and owner manuals for the S Type that I think covers your car. Just do a search on some of his past posts or on Workshop Manuals.
18 hours ago, Raistlin said:
Fluid level at best. Torque converter at worst, I'd say.
There’s a gearbox fluid leak just a slight one but I’m just waiting for the parts to turn up then get it done
