I've been working on a home set up with SDD and Mongoose interface cable.
V130 SDD set up on a dedicated XP Dell laptop. Drew MongoosePro driver 32 bit installed.
No internet connection.
BIOS date set to overide the actual days to less than 21 days of last sdd update in system information.
Works a treat.
Battery voltage must be maintained between 13-14 volts with a source that can suppy a sustantial amount of current.
Wife's car idling with jump leads to my battery worked perfectly.
Recently had to clear adaptions on my transmission and look for codes.
Very useful tool - I will spend some time going deeper into all the engine parts to see if there are other hidden warnings or codes.
Even datalog as you are driving.
  • 7 months later...
May i ask where you bought you cable from? Im having loads of problems getting my lead to talk to my laptop.
Dan
