Hi Nick,
The Jaguar label on top of the battery seems a clue to the fact that the battery was Jaguar fitted..  I always write the date of fitting a new battery on the battery myself.
The varta battery I changed  last year was one that you didn't have to top up with distilled water, which is an indication of its age.
I can't seem to find any indication of date but I have tested the voltage and it averages out at 11.6v which is too low for a 'good' battery.
The upshot is that I'll get a replacement battery before the cold weather leaves me stranded 😞
Thanks for all the helpful comments, much appreciated.
Nick
I decided to replace my battery and used Halfords Autocentres to do it. They gave me a very good price for a Yuasa battery (£147.00) and included the fitting, saving all the car settings and getting rid of the old battery. They were very polite and did a good job. I know some people don't like Halfords but I thought they were ok.
for that price I would of bought a AGM battery from the battery mega store, hankook agm, superb battery, gel dont leak, well recomended, 5 year garantee https://www.batterymegastore.co.uk/hankook-sa59520.html
also are you a member, did you use your 15% off card from the jaguar owner club at halfords
They take your old battery away because a lot of scrap places give 10 to 15 pounds now scrap value for a battery.
But yes your right Theres some serious weight in them
I changed my battery in December 2016, when it was just 5 years old.
We have a small accessory shop  very close to where we Iive which I always use.  I got a Platinum Battery fitted for £102.  They are heavy things to lift!
I have been having battery problems on and off for the last year. Drove down to Cardiff Friday afternoon ,no problems ,went to move the car a couple of hours after arrival and I have a full failure display , New battery fitted,but I was surprised that the failed battery was only 650 watt and a Jaguar battery where as the replacement is 900.
Hi Mike,
I have come across this before.  A member, who had just bought a Jaguar found that the heating and demist systems were not working and when I said it could be the battery he told me that a new one was fitted by the dealer from whom he bought it, and sent me a photograph.  The battery was a 500amp and would have just about started a mini.
I have a Platinum 800 amp on my Jaguar and as I don't do many long trips I put in on charge once a fortnight.  Luckily I have an exterior socket outside the garage, and it is doing its job now.
Cheers peter,You cannot even trust main dealers. All I have to do now is repair or replace the battery hold down strap,bolt sheared,ah well never a dull moment.
