Been offered a 3.0 sport auto for small money. Car will only go in reverse. Seller says it needs new sensor which is located by the sump. Does that sound possible and is that an easy fix for a diy,er?
What year , what car
if its the zf 6 speed auto, then none of the sensors are easy to change
but could also something as simple as the cable requiring adjusting between the j-gate and gearbox, this will give similar faults
all depends what condition the car is in and how much its selling for
5 hours ago, JOE-DOT-COM said:
2003 £400 S type
Unless you're happy with finding where the fault(s) lie, or you can take someone who can, personally I wouldn't touch it. It's £400 for a reason.
If it's a stretched cable, great, but if it's a broken gearbox you're looking at big money.
Cheers, Mark
