HI all.
not sure but I got a puncher in my rear tyre, but does a 2011 lux pre supposed to have sensors on to warn you have deflated tyres, or are they an extra you have to fit. also both my front head light dipped beam bulbs went should a warning come up about these come on dash computer mine has not ?:shy:cheers Dave.
Hi Dave, have a look at the valve stems and if they're metal and have a nut fixing them to the rim, then you have the TPMS, if they're just ordinary rubber valves with no nut, then no. I don't think they have a dashboard failure indication for the main headlamps bulbs.
Regards, Kie
