Hi All,
Was wondering if any one has had any experience with a sticking rear door lock. When locked, using the central locking, it wont fully unlock and you can't open the door. If you unlock from the inside and then use central locking it wont lock. It's like there is resistance in the mechanism which you can feel when operating it manually from in the car. The little lock/unlock lever above the handle moves a little but not fully in either direction, unless moved manually.
Badger
