hi all any one else had this problem, when it has been cold when trying  to start my 2011  XF the start  button comes on but it will not start, the brake pedal is rock hard so I have to unlock the car lock it again press the brake pedal very hard several time then it will start? this has happened now a couple of times anyone else had this happened. cheers Dave:shy:
Hi Dave
Had a similar problem with mine last year ,turned out it was the battery.  Seems you need to keep a good voltage otherwise the electronics go haywire !
All the best
Graham
