3.0 2005 anti-theft and steering column locked
Kris88
Hi all. I wanted to clear some DTC codes using SDD and after doing that the car didn't want to start. I have plugged the SDD back again and it gave me info about anti-theft active and steering column lock on dash as well. After re-programming immobiliser car has started as normal. Have I missed something when clearing DTCs? It has happened twice now and I'm really concerned what's going on..
This exact same topic has popped up somewhere else, no matter which forum you go to you will get the same answers
I've used IDS/SDD for years to check and clear codes and to monitor live engine data and never had any issues
but I am using a dedicated laptop, not using a modern laptop running virtual software running win xp pro, this option will give you nothing but trouble and you will end up brcking loads of modules, because these virtual softwares are so unstable.
also I've not used IDS/SDD with out have a descent battery charger connected, mines 30 Amps and that really a mininum, Jaguar use a similar setup, because when your diagnosing, programing or calibrating, it asks you to cycle the ignition many times and will flatten the battery really quick, low battery voltage causes modules to go into fault and if you programing, calibrating or even clearing fault codes, if it goes into fault mid writing will corrupt the module, depending what its doing, the modules may not be recoverable, damaged for good.
looks like you have been lucky if you got them working again
also found version V130 the most reliable and covers the most on S-types
Well, if I'm not getting any help I'm trying somewhere else- that's obvious.
I am using dedicated DELL with WIN XP PRO SP2, clear system with v130 SDD only, no other programs on it. I've had brand new Bosch battery fitted when I was doing that and SDD was connected just for 10 minutes.
