hi i have a 2004 2.7 v6 and loveit to bits but the latest problem has got me stuck
i have stoped using it every day and brake wise it hasnever missed a beat  80 miles a day  but now changed jobe 3 miles from home so wont use the jag but give it a run once a week and use it week ends
all good untill friday drove to work great after work jumped in it drove a fewmiles to the petrol station filled up drove off and all hell broke lose abs lights on gearbox fault etc first thought low battery
but pluged my i car soft reader in and i can check codes for any part of the car except the abs system it wont conect
any idears my thought are the abs unut found a company that will rebuild it to save getting it reprogramed but will cost £200
battery is almost fully charged after 24hours so will try agaig but last atempt was @ 12.10volts so not holding my breath
low battery, put battery on charge overnight and try it then
low battery on these causes all manner of problems
if your only doing 3 miles on a diesel, it wont put back into the battery, what youve taken out on first startup
I would personaly get a smart charger like a ctek and keep it on charge when not in use, it will keep your battery tip top and you wont get any more issues
Right update ABS came back no faults checked the loom from the abs to front lights found a bad earth and now i can use the obd11 reder and now i get
steering wheel possision sensor
gearbox ratio wrong
also brought a cheap chinese vacume bleader that goes on an air line and it made bleading the system so easy
so any idears i will charge the battery again just incase
AT last its done first battery reads 12.3v
after the earth behind the right hand light was cleaned off  after a few shore runs i got rear right abd sender down and steering angle out replaced the ABS sensor but left the battery and steering angle sensor
had a drive and no trouble codes so happy days will keep driving it and hopefuly all finnished
