Hi, I am new owner of this type of Jaguar XE 2016 (2.0tdi 163hp). I want to change the Oil in the gearbox (automatic) and differential. What kind of Oil can you recommend and their type?
The gearboxes are supposed to be sealed for life, which is absolute rubbish
well worth changing the Oil, will prolong the life
but I would only use genuine zf parts, I think your has the ZF 8HP45
I use something like this https://www.ebay.co.uk/itm/genuine-jaguar-xe-zf-8hP45-automatic-transmission-gearbox-pan-sump-filter-7L-oil/263773343119?hash=item3d6a1dcd8f:g:3Z8AAOSwBgZdNgHr
for a few reasons, it left the factory with that Oil, the TCM is submersed within the Oil in the gearbox and when you change the oil, some oil stays in the torque convertor and it can only be drained completely by removal only, mixing different oils is always a bad idea
P.S, here a link to work shop manual to make things easier https://www.dropbox.com/s/ee2nxkx6fgqmb25/workshop_manual.zip?dl=1
  On 12/19/2019 at 9:01 PM, JOE-DOT-COM said:
well worth changing the oil, will prolong the life
for a few reasons, it left the factory with that oil, the TCM is submersed within the oil in the gearbox and when you change the oil, some oil stays in the torque convertor and it can only be drained completely by removal only, mixing different oils is always a bad idea
Ok thank you very much !
