I had a flat battery and took out but closed the boot,  anyone any idea how I can open the boot to fit the battery
I'm new to Jaguar ownership but I have noticed that there is a place in the engine compartment to attach jump leads/battery charger! Possibly connect a charger to this and see if you open it that way! Like I say I'm new to Jaguar so might be talking got air!
Good luck.
If the OP can't open the boot, he may not be able to open the bonnet either  - unless he can open the  car doors to be able to release the catch.
My XK has a lock behind the rear number plate, which you can turn with the key to open the tailgate if the battery is flat.
Maybe the XE has something similar?
Using a battery or battery charger, momentarily apply 12 volts live to the bus bar in the fuse box and earth to any bolt on the chassis / bodywork in the engine bay.
Press the boot button. Job done.
I assume your doors are not locked. If they are, use the skeleton key in your key-fob to open one.
Thanks everyone for comments, i connected the battery with jump leads to the section in the engine and it freed us the boot.
Managed to get in and reconnect my new battery
