I am buying a 2012 XF and the air vents do not rotate when you start up , do all air vents rotate or is there a problem.Thanks.
If the heating / ventilation is off they will remain closed. Have you checked Heating ventilation is switched on?
  • 7 months later...
There is a setting to determine whether they open or not - if it is set to 'not', then they will only open at start up if the climate control was on when you turned the car off...
Trust this helps
IanL
  • 3 months later...
The vehicle battery is probably low or on it's way out, try charging the battery. My car only gets used once or twice a week and the same would happen. Worked after charging battery or after a bit of a run out. Eventually had to replace the battery.
