I know it's the attitude of a dinosaur but I LIKE being able to see the water temperature gauge and on the X250 it isn't there.
Has anybody seen a neat and inconspicuous version of those OBD 2 displays that will do the job without violating the interior please?
  • 6 months later...
Unsure if you are still looking for this information?
Like you, I need to be aware of my coolant temperature too. There seems to be a variety of devices available, but really the only area you need to be careful of is whether you use iPhone, in which case you need a WiFi device, whereas Android can use bluetooth versions. I use iPhone, so the one I purchased from eBay:-
https://www.ebay.co.uk/itm/WiFi-OBD2-ELM-327-Bluetooth-Car-Scanner-Android-iOS-IPhone-Torque-Auto-Scan-Tool/283645981441?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2648
I think the critical bit is OBD2 ELM 327 for a more general search...
Hope this helps
IanL
On 1/9/2021 at 5:19 PM, Tomato said:
Torque pro app got loads of great features worth getting if you have a bluetooth obd2
Unfortunately, these only seem to be compatible with Android devices - unsure why, as iOS (Apple) devices support bluetooth, (my battery monitor connects via BT), but with the limited research I have done, this seems to be the case...
